Use Boss Kut Designs with SCA?
CBJPL31
Re: Use Boss Kut Designs with SCA?
Post by CBJPL31 »
Deleted
flourish.svg
(7.82 KiB) Downloaded 1030 times
~Nicole~
susibi
Post by susibi »
OK - now open Inkscape and import the jpeg.
The go to Path>Trace bitmap
When the window opens set the brightness threshold at 0.650
Click on update then ok and the window will close.
Click on the image on your page , move it to one side and delete the original image.
Save as .svg
HTH
Susibi :D
susibi
Post by susibi »
OK I've seen the .svg - it opens perfectly in SCAL but remember you can't share as it's copyrighted so if I were you I'd remove the link as I was able to access it no problem!
Susibi :D
CBJPL31
Post by CBJPL31 »
susibi wrote:OK - now open Inkscape and import the jpeg.
Save as .svg
HTH
Susibi :D
Wait....why am I doing this?
I just cut the file.
I am super-excited!!!
But I'm confused about this step?
What is the purpose of changing the brightness threshold?
~Nicole~
