snowflake double frame(card)
Re: snowflake double frame(card)
OHHHH, this is soooo pretty!!!!...I love SCAL and all that it can do. I was wondering about the small section on your, but now I get it. I did not make any 4 panel...I don't have long paper, but now I can still do it!!! Thanks!!!
You can make the long card with two 8 1/2 x 11. In the experimental one that I posted, you can see that there is maybe a half inch extra card ( two sections welded with the 1/2 inch welded to it.) which you line up with the first of the double sections. does that make sense? The first double section is 9.183 x 5.50. The second with the extra attached is 9.887 x 5.50
when you glue the two sections together, it makes the entire card 18.381 x 5.50. Of course you can make it as big as you want. I did notice that Susan's Edge fonts had lots of nodes in them. I take them into Inkscape , break them apart and make the outer edge a little larger, just use the nodes I need and then combine them again.
- pict of card.JPG (24.43 KiB) Viewed 8963 times
Oh you guys...these ARE SO GORGEOUS!!!!! LOVE LOVE LOVE them!!!!!
