Help with this file-Inkscape
lindamac
Location: Arizona-SCAL1, SCAL2,SCAL3 Inkscape,Silhouette Cameo
Post by lindamac »
I've been playing around with the Edges fonts from Susan Blue Robot. I got the edges to connect to the card but for the life of me I can't get the edges of the card to weld together in Inkscape. I've tried every button under Path and even a combination of buttons. Can you tell me what to do?
experiment.svg
(46.66 KiB) Downloaded 242 times
HeatherM
Re: Help with this file
Post by HeatherM »
Hi Lindamac, you have Groups in your file and you can't use Union on a Group. Both of your card pieces are grouped (more than once each). Ungroup them (either right click or use the Object menu) and then you can use Path/Union. Watch your message bar at the bottom of the Inkscape window to see what type of things are selected (Path, Group, Shape). HTH
lindamac
Re: Help with this file-Inkscape
Post by lindamac »
Thank you Heather, it worked!!!! Inkscape was so big on my screen I couldn't see the bottom part where it said there were groups. I've made the screen smaller so I can see everything. Altho I've been using Inkscape for years, there is more that I don't know than I do know!
