Has anyone worked this out. I want to stamp an image, cut it out on my eclips then cut a slightly larger version as a mat. Once I have the first bit mastered I am fine with the larger mat but I can't work out how to add the registration marks.
Sorry if this has been dealt with I have looked but can't find anything.
TIA
Stamp to Cut???
Stamp to Cut???
Eclips, Ecal, Adobe Photoshop
Re: Stamp to Cut???
viewtopic.php?f=84&t=28041&p=108398&hil ... ks#p108398
Sounds like you will have to trace the image first...here is some information.
Re: Stamp to Cut???
I have just worked this out with a Silh, and you may be able to use a similar technique with the eclips.
http://cleversomeday.wordpress.com/2012 ... atemethod/
Re: Stamp to Cut???
That's perfect, I will give it a try later.
Thanks as ever.
Thanks as ever.
Re: Stamp to Cut???
I did something similar, traced my stamped image, made a shadow layer, than printed that with registration marks on vellum, punched the registration marks with a very small circular punch, and so on.... I only have a picture of one I traced in MTC because Ecal kept crashing on me. But it is just to get the idea...
- pnc 2.jpg (48.22 KiB) Viewed 6029 times
Ineke
Netherlands
Ecal2/eclips
Netherlands
Ecal2/eclips
Re: Stamp to Cut???
Thanks for sharing that, Ineke. I thought it might be easier on the eclips and it definitely is because you only need the dots and not the L brackets! Have you posted that on a blog or anything because I know a lot of Zing people would be interested in that.
Re: Stamp to Cut???
Found it and that was a thread I was active in! I bumped the thread over there.
