very strange
very strange
I have a request to make this in vinyl,I have the 1st sure cuts alot program and use inkscape to confert the file into SVG's ,,andthe image looks fine when I do it,,,but when bring it to the cutting program in it all out of order or should say the 9's are,,I have never seen anything like it before,has anyone ? can anyone make this into a svg so I can cut it?,,,lol [img
- e red 22.jpg (161.79 KiB) Viewed 3724 times
Re: very strange
Try going back to INK and select the objects and then do a Path>Combine. Since nothing is touching, or at least I don't see any of the objects touching, you shouldnt have a problem.
HTH
Althea
HTH
Althea
Re: very strange
here is the image i'm try to turn into svg..not working
- el99_final.jpg (266.83 KiB) Viewed 3718 times
Re: very strange
Why not maybe just trace the image in SCAL and cut. Just a thought.
Re: very strange
I redid a file too, so I'll attach it. Now you have choices. =)
- drawing.svg
- (20.96 KiB) Downloaded 240 times
Re: very strange
Thank you all so very much,,think its going work!! ..never had this kind of problem before,,but Thank you all!!..great board..knew someone would be able to help me!!
