Diagonal weave basket in vinyl tarp
SewnAgain
Post by SewnAgain »
Basket was cut from two pieces of non-adhesive vinyl billboard tarp that was printed on both sides. I put the two pieces of tarp at right angles to each other, then wove the walls. This project might work well in paper also. To finish the raw edges I glued another piece of tarp around the top edge. Suitable glues are Vyna-Bond or Lepage Flexible Plastic Adhesive. More pictures of this project here: http://vinally.blogspot.com/2009/12/dia ... asket.html
I also use UHU stick to make the vinyl tarp stick to the Cricut Expressions cutting mat. Max pressure and Max blade depth, and fast cutting speed.
Happy Crafting!
Alison Lait
http://www.vinally.ca/
4inchbasketdiagonalweave.svg
Svg file for diagonal weave basket. Cut two.
(5.01 KiB) Downloaded 349 times
VinAlly
Advertising tarps, repurposed
Scrapper Lady
Re: Diagonal weave basket in vinyl tarp
Post by Scrapper Lady »
You have an interesting blog with a lot of very creative ideas! Thanks for sharing!!
Robin
