Hi, I am needing a circle of 1 .3/8. With another circle of.10 Its for the tealight candles to cover the front of one and then for the wick. I made one but i am trying to copy and paste and can only copy 1 circle ... Anyone care to make this and tell me how to so that way I can do my own next time ?
Thank you
Well after playing I thought I got it , but only the outside circle would cut... so how do I get both to cut?. any suggestions will be happily received.
T
need a circle within a circle
Re: need a circle within a circle
You can do that right in SCAL just draw the size of the circle you want and then getting a duplicate of that circle and bringing it down to the smaller size you need...
OK,... then do i weld it as I need to make about 50 of these... so i want to copy and paste .... when I did that the bigger circle cut but not the little one.... what did I do wrong that both circles didn't cut? Thank you for the help
Don't weld them, the inner circle won't cut if you do. If you have SCAL2 you can select both circles and use Object/Group from the menu. Then both circles will stay together when you copy/paste them. HTH
Here is a file with 49 of them. When you import this file into SCAL, it should measure 10.41" x 10.11".
