Print and Cut registration marks setting
I have seen to go to Cutter>Cutters Settings and you will see your reg mark settings and laser calibration. I am using SCAL 5 and do not see this option on my screen. I am using Cameo Silhouette cutter and the cut is not exact. It is cutting to the left of the image.
- Untitled.png (1.34 MiB) Viewed 3077 times
Re: Print and Cut registration marks setting
As I recall the calibration is built into the firmware on the Cameos. So, the first thing I would do is try the same or similar print-and-cut from Silh Studio and, if it's off in the same direction, then use the calibration correction procedure. Here's a link to Silhouette's page for that:
https://www.silhouetteamerica.com/faq/s ... utting-off
