Random Lines across page
macdeath
Post by macdeath »
Hi,
I tested SCAL before buying and I had no issues, however, after purchasing, I get Random cut lines all over the page.
If I send the same cut twice, the random lines are in the same place.
I have reset the cutter to factory default, and I have tried another USB cable.
I am using a Bascocut C-24L cutter.
What am I doing wrong?
Re: Random Lines across page
Not sure what would cause this BUT I assume these cut lines are NOT the same ones you saw when test cutting in trial mode?
Are you on a PC or a Mac? What O/S? Is this regular SCAL or SCAL Pro? And when you launch SCAL, what is the version number appearing in the opening splash screen?
Busgoddess10
Post by Busgoddess10 »
I have also had this problem. And it is random. No rhyme or reason.
And it has been around quite a while. Even before I upgraded to 5 pro.
