Happy Thanksgiving
jasenj1
Happy Thanksgiving
Post by jasenj1 »
Here's a "Happy Thanksgiving" I whipped up for my wife. It uses the Harrington font. It cuts slowly because there are so many nodes. The words are pretty delicate and I had trouble pulling them out of the cut paper. I'm not sure if there is a setting I can change to make it pop out cleaner, or if that's just the nature of the beast with such a delicate cutting with sharp angles.
- Jasen.
EDIT: Uploaded simplified version.
Happy Thanksgiving.png (53.46 KiB) Viewed 4813 times
Happy Thanksgiving Paths.svg
(97.42 KiB) Downloaded 496 times
sunnyNP
Re: Happy Thanksgiving
Post by sunnyNP »
awesome! thanks for sharng
TheresaTT
Post by TheresaTT »
like that font. Thanks.
Theresa
sensationallychic
Post by sensationallychic »
Jasen, you can reduce the number of nodes by using path>simplify. But before you do that, you should read this post http://forums.surecutsalot.com/viewtopi ... ify#p19364 that tells you how to change the simplify threshold in ink to keep your image from getting distorted when using the simplify action in ink. Believe me, you'll be glad that you did! ;) Very nice file BTW, thanks for sharing!! :D
jasenj1
Post by jasenj1 »
sensationallychic wrote:...change the simplify threshold in ink to keep your image from getting distorted when using the simplify action in ink. Believe me, you'll be glad that you did! ;)
Thanks. That's the tip I needed. 0.0005 still distorted things more than I liked, so I went to 0.0001 - the smallest possible. It still cleaned up a bunch of nodes. I replaced the upload with a new version.
- Jasen.
sensationallychic
Glad I could help!
msgriff_55
Post by msgriff_55 »
Thank you so much!
scrappercarmen
Post by scrappercarmen »
Very fancy, thank you!
Carmen L
