Cutting so slooooooooow . . . :(
PDG
Post by PDG »
i'm stumped. i'm trying to cut a flower - very basic (attached).
it cuts so slow. settings on my baby bug are 3, 4, 3 - does SCAL override those? reason i ask is because i cut a flower from my walk in my garden cartridge (same fabric and settings) and it just zips right through.
is something wrong with my SVG file?
thanks to anyone that can help!
patty
aprilflowersD.svg
(67.51 KiB) Downloaded 189 times
GrammyKrausse
Re: Cutting so slooooooooow . . . :(
Post by GrammyKrausse »
most likely it is because there is 1085 nodes. That's lot's of them
Grammy :D
DogCarbon
Post by DogCarbon »
I took a look at the svg file and it has a ton of nodes.
the more nodes the longer it takes to cut.
You can go into inkscape and delete them... if you need help, check out http://susanbluerobot.blogspot.com/2008 ... inish.html on how to manipulate the file
PDG
Post by PDG »
so by simplifying, i got it down to 31 nodes?
aprilflowersD.svg
(4.39 KiB) Downloaded 152 times
GrammyKrausse
I usually just delete the extra nodes in Inkscape, I have control over the shape that way. To tell how many nodes your project has. In Inkscape select your project with your curser and down in the middle bottom it will tell you how many nodes are there.
PDG
Post by PDG »
yep, i just cut it again and it worked! guess now i'll have to slow the speed down 'cause it went really fast!
thanks so much! i see where the nodes are indicated at the bottom of the screen! obviously i'm new at this!
DogCarbon
Post by DogCarbon »
ya'll are faster than me as I got it down to 18 nodes....
aprilflowersD_2.svg
(71.24 KiB) Downloaded 190 times
GrammyKrausse
Glad it worked for you
