I made these .jpg files so I could use the Trace Image feature in SCAL 2.
If you have Scal2 and would like to use these Stampin' Up! punches, then all you need to do to use
them is:
1. Save images to your computer where you can find them.
2. In SCAL2 click on Trace Image>Browse and find the file you want to use>Open
You can click on the Preview to see how the file will cut if you want.
3. Click OK and the file will be put on your mat in Scal ready for you to size and use.
Hope you find these useful!
Stampin' Up! Punches To Share!
- Modern Label Punch
- SU_Modern_Label.jpg (2.17 KiB) Viewed 4854 times
- Curly Label Punch
- SU_Curly_Label.jpg (2.81 KiB) Viewed 4854 times
- Butterfly Punch
- SU_Butterfly_Punch.jpg (3.16 KiB) Viewed 4854 times
Re: Stampin' Up! Punches To Share!
Just came across these - thanks!
Thank you for sharing these files! Do you happen to have the tab punch image? I really want that punch but I don't want to buy it knowing I could probably cut it on my cricut....
Here's a link that might help you out:
http://forums.surecutsalot.com/viewtopi ... abs#p71531
Also, if you ever need a file of a specific design, try using the search option in the upper right-hand corner first. There might be one already posted to this forum.
