coffin box by Martha Stewart and Cluster of Breast Cancer Ri
joesally
Post by joesally »
I am looking for two things.
1. I need a cluster of three small design of breast cancer ribbons with stems on them (like a bouquet) where they kind of come together in the middle and in stencil design so I can cut one out and heat set it on a t-shirt. I plan on putting a tiny ribbon making it look like I gathered them altogether in a bouquet.
2. Has anyone done a svg of Martha Stewarts coffin box template? I would love to have it as I am making around 50 of them and would love to just cut them out by machine rather then by hand.
Thank you so much.
Sally
joesally
Re: coffin box by Martha Stewart and Cluster of Breast Cancer Ri
Post by joesally »
I have done most of the converting to svg but for some reason, the inner part of the coffin which is the center cuts out also. Also, the left hand side cuts out one of the pivots and makes its own shape. Could someone help?
tjputvin
Post by tjputvin »
Hi,
Wendy from "Lets Be Scrappy" posted the Martha Stuart coffin box today..
http://www.letsbescrappy.blogspot.com/
Wishing you abundant blessings,
Tami
joesally
Post by joesally »
Wendy, Thank you Thank you Thank you for the coffin box.
Sally
Is this what you wanted for the ribbons?
ribbon bouquet.png (18.68 KiB) Viewed 3238 times
ribbon bouquet.svg
(10.71 KiB) Downloaded 241 times
Aussie Wendy
Post by Aussie Wendy »
joesally wrote:Wendy, Thank you Thank you Thank you for the coffin box.
Sally
You're very welcome Sally. And thanks to Tami for emailing me your Thankyou reply :)
I posted one here a few weeks ago...http://forums.surecutsalot.com/viewtopi ... fin#p33480
Rorysnonna
Post by Rorysnonna »
Hi All,
here is Martha's box as an scut from scal 2. there are no score lines or open paths so it is ready to go. The score line guides can be found on Marth's web site or with one of the previous downloads. I cut one and it is so cute but I have so many favors to make that filling them would take so much candy. I might try to make smaller ones. not sure just yet. Anyway hope this helps someone out. All I did was open the KNK file from the previous download and exported it as a bitmap and auto traced it. This is a fast way to convert things to an scut when there are many open paths. I think this can be done with inkscape as well. Happy Cutting!
Lysa
marthas coffin box.scut
(11.83 KiB) Downloaded 186 times
Rorysnonna
Hey All,
I like this even better. Its smaller, cuter and has layers so you can cut the bottom or the top. And its small enough that the candy fill won't break the bank!
Lysa
small coffin.scut
(11.5 KiB) Downloaded 198 times
