scal5 crashes on graphtec
moedope
Post by moedope »
hi been using scal5 on a gcc expert 2 fine but ive just got a new graphtec ce5000-60 and everytime i try to do a connection test scal crashes, its connected to usb and cutter is working with other cutting softwares
moedope
Re: scal5 crashes on graphtec
Post by moedope »
ok ive got it to cut but now my cuts are way smaller than what my files are, were can i start to correct this
In the main SCAL screen, go to Cutter>Cutter Settings. You'll see a drop-down menu called Step Size. Experiment with other options in that menu until your shapes match the design size.
peterman3
Post by peterman3 »
moedope wrote: Fri Apr 09, 2021 8:03 am ok ive got it to cut but now my cuts are way smaller than what my files are, were can i start to correct this
Hi, I have the same cutter and it crashes when I do a Test, if you dont mind sharing how you fixed it.thx
