ISO: Halloween Treat Box file
Looking for something cute that would make a halloween treat box. Maybe a coffin shape? or pumpkin? Thanks!
Lots of cute, paper piecing files on my blog - all free!
http://papercreativity.blogspot.com/
Love my original SCAL =)
Re: ISO: Halloween Treat Box file
look here for coffin treat box should be easy to import into inscape
http://www.marthastewart.com/article/co ... 09a00aRCRD
There is one for a coffin right here on our site that I posted a few weeks back if you are interested.
http://forums.surecutsalot.com/viewtopi ... fin#p33481
If you type in the search box at the upper right hand corner a lot of times you will find the svgs or scuts that you are looking for.
Thank you!!! Perfect
The Coffin Box at the Martha Stewart site has vector PDF files for the templates. Easy to open in INK and save as SVG Files.
I have scal original. I cut the coffin file that you posted above but it cut on the "score" lines so it winds up in 10 pieces. Do you have that svg file without score lines?
Thanks!! My sons class will love this
Use blackout. I tried it just to be sure (in SCAL 1), and that will work for you.
Okay!!
How do I use blackout in scal??
In SCAL 1 you open Style in the Properties box to select blackout, etc. If you can't see the box, you need to click on Window and then Shape Properties.
In SCAL 2, Style is found in the Appearance area listed under Position/Size area of the properties box (that only seems to open up/be available if the item/svg is selected/highlighted!) If you unselect the item the propeties box goes back to 'document and page' choices instead.
Someone please correct me if I'm wrong or explaining something the 'harder-long way'.
Donna L
Donna L
