Pumpkin Patch - Inkscape .47 SCAL1
NOTE: I had to fix the files after others pointed out errors So scroll down to the latest posts from me and get the fixed ones there.
Just playing around practicing my stick figure drawing skills (such as they are). I also tried Inkscape .47.
I have opened the file in SCAL1 with no problem, so you can for sure use it.
What I'd like to know in exchange for the file.
1. Can you open/use in SCAL2?
2. Can you open/change in Inskscape .46
The cornstalks are a snatch from the internet, I drew the frame. No sense making this any more problematic than necessary,
I'd really appreciate hearing from you.
More about the drawing part and the tutorial I used is on my BLOG
Funkay Monkay Mamma
Re: Pumpkin Patch - Inkscape .47 SCAL1
Post by Funkay Monkay Mamma »
Opened it in SCAL with no issue.
Too cute!
TFS
Thank you so much for letting me know. I assume SCAL1? or was it SCAL2?
raewyn64
Post by raewyn64 »
I opened it fine in SCAL1 & SCAL2 if that is any help to you.
I also opened it in Ink.46 no problem and was able to edit it into layers and then save it and import it into SCAL2 and it came through in the layers I had made in Ink.
It did everything I would expect it to do.
Raewyn
Thanks Raewyn
I was concerned about posting any files made in .47 without testing.
I'm greatful for the time!
This is a close up in SCAL2.. If you notice some of the circles aren't joined and the "O" in boo as well
Thanks Joann
I think I fixed it, at least for SCAL1. In SCAL1 I didn't have the open lines in the pumpkins but did see the open circle in the font and that one of the small leaves for the pumpkin had not "welded" properly.
Here are new files.
Picture 1.png (19.21 KiB) Viewed 3269 times
It is not clear that this file is worth bothering with but I'm learning a lot! Thanks also to all the other designers who chimed in on other posts.
pumpkinpatch.scut
(28.75 KiB) Downloaded 135 times
pumpkinman2.svg
(22.97 KiB) Downloaded 140 times
Butterfly
Post by Butterfly »
These are too cute
Scrappin My Way Through
