SCAL Freezing/Not Repsonding in Windows Vista
Common questions/answers for version 2 of Sure Cuts A Lot
craftedge
Site Admin
Post by craftedge »
If you are using Windows Vista and are having problems with the program freezing/crashing, you will need to run Sure Cuts A Lot in Windows XP Compatibility Mode.
1. Right-click the "Sure Cuts A Lot.exe" and choose Properties from the context menu that appears. The exe file is typically located at "C:\Program Files\Craft Edge\Sure Cuts A Lot"
2. Select the Compatibility tab and enable "Run this program in compatibility mode for:", and choose "Windows XP (Service Pack2)"
3. Click Apply and then OK to save the changes.
