What File Formats Can You Save Your Projects As?
lov2teach
Post by lov2teach »
Can you save your project as a .svg file? I would like to design in SCAL and then take the svg file into my cutter software to cut the file.
Thanks for your help.
Donna
Re: What File Formats Can You Save Your Projects As?
In SCAL, you use File>Export in order to save a file in a different format, like SVG. The default is SVG but there are other options you can check if you need something else at some other time.
