Ok, I admit it...I am totally lost when it comes to Inkscape. I have Googled, but can't find a circle outline. I need one that is kinda thick, not thin. Most I found were too thin.
Heather!! Todd!! Someone!!! Help...PLEASE????
Circle outline
Re: Circle outline
I posted a thinner one here. http://forums.surecutsalot.com/viewtopi ... 48&p=20154 You should be able to make it thicker in SCAL using the shadow feature. Here is another one that looks more like a doughnut or a lifesaver. This kind of thing is very easy to make in Ink. Use the circle tool with the control key. Make another circle the same way, but smaller. Select both and use the alignment tools to align them. Then Path/Exclusion. HTH
- circle doughnut.svg
- (2.69 KiB) Downloaded 144 times
Re: Circle outline
Girl, you are a lifesaver! I had searched on here for circle, the ring didn't come up.
THANK YOU!!!! You're the greatest!
Re: Circle outline
This circle "frame" might also help ...http://www.myvinyldesigner.com/Products/sh003.aspx ... M~
