Font too skinny to cut?
Share your favorite fonts to use in Sure Cuts A Lot
sillymommy
Post by sillymommy »
Hi,
Another newbie question about fonts.....I downloaded KK Monogram and love it. I tried to cut 3 letters welded together. The letters were too "wispy" and didn't hold together when I pulled the paper off the mat. I want to cut a monogram out of vinyl for the car window. I need for the letters to be fat enough to be sturdy, but still look like the font. I went to "Properties" and clicked "Shadow" but it changed the look of the letters. Didn't look as elegant. How do I "fatten" up the letters so they will still look right? Any help would be appreciated! Sonya
Re: Font too skinny to cut?
Did you change the number of the shadow to "1"? There is a box to the right of the drop-down box when shadow is selected that lets you adjust the size of the shadow. 1 is the smallest. You can also use the linked offset feature in Inkscape.
firstcut
Post by firstcut »
This is an example of a monogram I did with that font with the shadow set to 1. Once I learned this tip I was able to put a lot of my fonts back into the cuttable category.
sillymommy
Thanks so much. I'm off to give that a try. Your mongram looks awesome. That's what I want to do. Wish me luck.....
sillymommy
I tried setting it to "1", but most of the letters on the sides disappeared. Weird. The letter in the middle didn't disappear, but the ones on each side of it disappeared when I set them to 1. Any advice? Hmmmm......Thanks for any input!
lesliefolks
Post by lesliefolks »
I always always for get you can change the shadow!! thanks for reminding me!!!
MotherGoose09
Post by MotherGoose09 »
I've tried to download this font a thousand times and it always says that this is not a valid font file when I try to install it. I downloaded it from www.abstractfonts.com. Do you have any suggestions? Did you have trouble installing it? Please help!! I'm about to go NUTS!!!
BTW... I did unzip it first. LOL
When you unzipped and extracted it did you right click on the file that extracted and hit install???? You have to install the font first. If you are just clicking on the file that is why you get the error message.
Maggie
Post by Maggie »
WOW! I didn't know you could change the size of the shadow to make a font more cuttable. I've had it a year. Where is that handy info in any of the tuts out there? Someone missed that! I'm excited.
As to this font, it's gorgeous! I can't wait to find it! Thanks gals!
donnajivan
Post by donnajivan »
Thanks for the information! I was having an awful time cutting words out, I didn't know about changing the shadow size!
