Double lines when importing svg to scal
LadyBug
Post by LadyBug »
I traced a heart in inkscape and it looks great, or at least I thought. When I went to import it into SCAL I have double lines. I went back into inkscape and couldn't find anything that looked wrong but decided to flood fill my design and sure enough there is a small second line around my image. Can anyone tell me how to get rid of that second line? I am very new to all of this but I am a quick learner :D
I tried going into the nodes but it only shows one line when I do that...thought I could just delete the extra line...thunk wrong!
I have attached pictures, I hope someone can help me understand this.
Thanks!
This is the svg file when brought into SCAL
This is the view of the file in inkscape just before saving as a .svg
kkrewtea
Re: Double lines when importing svg to scal
Post by kkrewtea »
I took a stab at this and it worked!!! Yahoo! I broke it apart, got rid of the stuff you didn't need and then combined it....Never did that before but I'm excited!!! Now if I can get it to attach to this post I'm on a roll!!!
IT WORKED!!!! You'll have to change the view to outline though...
heart flourish.svg
(7.6 KiB) Downloaded 294 times
Shirl
LadyBug
Post by LadyBug »
Ok can you tell me what you did to get it to work? LOL
The steps you did so that I can try it myself :D
LadyBug
Post by LadyBug »
I figured it out! Thanks for posting what you did, I was able to figure out the steps and now the double lines are gone!
But does anyone know why it did it? Am I going to have to do this with every image I trace? Is there a setting or something that I can change to prevent this?
talanhart
Post by talanhart »
Very nice flourish!
LadyBug
Post by LadyBug »
Thanks Talan but I can't take the credit for it....I copied it from a cartridge :D
Just to see if I could do it.
raewyn64
Post by raewyn64 »
If you have an image that you trace in Inkscape and it has a thick black outline, Inkscape will trace on both sides of that line and so you get the double lines.
When you are in normal view in Inkscape you don't notice it, but if you go to Outline view you will see if it has the two lines and you can clean it up before taking it over to SCAL to cut.
You will find that it can be a regular thing so don't think it is something you are doing wrong or something wrong with your original image.
Raewyn
LadyBug
Post by LadyBug »
Thanks Raewyn!! That's a good thing to know and I appreciate you telling me. :)
firstcut
Post by firstcut »
An image like this is where the paint bucket really shines. Put the whole png image in view on your screen and then with the paint bucket (default settings) selected, click once inside the part of the image that will be solid when it is cut out. For instance, not inside the center heart, but in between the borders of a part of the lower flourish. Ink will trace the shape with a single outline.
Texasyl
Post by Texasyl »
How does one go to Outline view?
