New to Scal and Inkscape HELP PLEASE!
ornaments
Post by ornaments »
Hi I am new to scal also. Have had it for a week or 2 and watched many videos and all the questions on here. First of all I would like to thank eyeryone who posts here. I have figured out how to trace and save svg but having problems getting rid of lines I do not want. The example I am uploading is a card with a butterfly. I want the outer part of the butterfly to not be cut out of the card. I just want the inside square and butterfly to cut. How do I do that? Thanks so much
Mary
cardbutterfly.svg
(16.79 KiB) Downloaded 160 times
Re: New to Scal and Inkscape HELP PLEASE!
Is this what you want?
butterfly card.png (8.44 KiB) Viewed 1582 times
First ungroup both pieces in your file. I would guess that you imported both into your file? Ink automatically groups any vectors imported into a file, and SCAL doesn't like groups and misplaces/mis-sizes them.
Then Path/break apart the butterfly. Delete the outer rectangle. Select all of the butterfly pieces, and Path/combine. Move to where you want it on your large rectangle. You can leave it like that, or select both and Path/exclusion. The one antennae wasn't connected to the rest of the butterfly. I used the node tool to move the pieces together, then Path/Union to make them one piece.
Also, if you aren't planning on using some kind of backing to hold the circles in the butterfly, I would delete those while the butterfly is ungrouped so that you don't have to worry about them getting free of your mat and messing up the cut. HTH
cardbutterfly.svg
(16.64 KiB) Downloaded 152 times
ornaments
Post by ornaments »
Hi Thanks. I will play with my original. When I put yours into scal I see a few spots where the square around the butterfly isn't all the way attached to the butterfly. What tool Would I use to attach it? When I cut mine or the one I uploaded that you looked at in scal It cut the frame and butterfly out of the card. I wanted it cut so only the butterfly parts and the upper and bottom of the square that the butterfly was in to be cut out. Hope I made sense.
mary
