Can I open .FS file with sure cuts a lot pro 5?
struve2019
Post by struve2019 »
Can I open .FS file with sure cuts a lot pro 5? im not having any luck
Re: Can I open .FS file with sure cuts a lot pro 5?
I don't see .FS in the list of import formats for SCAL. What program saves or exports as .FS?
struve2019
Flex Sign
Ah, okay. Check under File>Export... there should be some options in common with SCAL whereby the vector format will be preserved. See if EPS, PDF, or SVG is one of the options. You might need to resize the file or perhaps remove a duplicate layer on top. But otherwise it should be easy to get it to work. Please report back if you have problems with getting it to work and I'll help some more.
