keyboard shortcuts
TLC custom stickers
keyboard shortcuts
Post by TLC custom stickers »
hi peeps
i am new to scal i have previously been using an outdated version of artcut. im just after a list of keyboard shortcuts to make life a little easier.. thanks in advance tash the hobbiest
Re: keyboard shortcuts
Here you go:
https://www.iloveknk.com/Support/Tutori ... rtcuts.pdf
And then, if you ever do need a detailed user manual (or other tutorials/videos) for any particular function, here's a link to my Support page for SCAL:
https://www.iloveknk.com/support/sure-c ... l-support/
cpking
Post by cpking »
Hi SandyMcC,
Thanks for sharing your awesome helpful PDF for Keyboard shortcuts .
My pleasure!
Snijderke
Post by Snijderke »
SandyMcC wrote:Here you go:
Hi Sandy,
nice to see the short-cut tabel. But I do n't see a short-cut for "Close project" and no for "close all projects". ???
Aha! Thank you! That shortcut was obviously (and logically) added in SCAL5 since SCAL4 didn't allow more than one project to be opened. I missed seeing it when comparing the two programs and updating the table. I'll get it added. If you find others, please do let me know. :)
Sandy
SteveMyers
Post by SteveMyers »
F1 key: Get help on a selected command or use the Office assistant.
Shift and F1 Key: Review text formatting.
F2 Key: Move text or image.
Shift + F2 Key: Copy text.
F3 Key: Insert an autotext entry.
Shift + F3 Key: Change the case of the selected text.
F4 Key: Perform last action again.
Shift + F4 Key: Perform a Find or Go To action again.
F5 Key: Displays the Go To dialogue box. You can also get to Find and Replace from here.
Shift + F5 Key: Move to a previous revision.
F6 Key: Go to the next frame or pane.
Shift + F6 Key: Go to the previous frame or pane.
F7 Key: Launch the Spell Checker.
Shift + F7 Key: Launch the Thesaurus.
F8 Key: Extend the current selection.
Shift + F8 Key: Shrink the current selection.
F9 Key: Refresh.
Shift + F9 Key: Switch between a field code and its result.
F10 Key: Show KeyTips.
Shift + F10 Key: Display a Shortcut Menu (same as right-clicking).
F11 Key: Go to the next field.
SHIFT + F11 Key: Go to the previous field.
F12 Key: Open Save As, equivalent to tools menu.
Shift + F12 Key: Save document, equivalent to tools menu.
Ctrl and A: Selects all in the current document.
Ctrl and B: Bold text.
Ctrl and C: Copies the item or text.
Ctrl and D: Displays the Font dialogue box.
Ctrl and E: Switch a paragraph between center and left alignment.
Ctrl and F: Displays the Find dialog box to search the current document.
Ctrl and G: Displays the Go To dialog box to search for a specific location in the current document.
Ctrl and H: Displays the Replace dialogue box.
Ctrl and I: Italicize text.
Ctrl and J: Switch a paragraph between justified and left alignment.
Ctrl and K: Create a hyperlink.
Ctrl and L: Left align a paragraph.
Ctrl and M: Indent a paragraph from the left.
Ctrl and N: Create a new document.
Ctrl and O: Opens a new document.
Ctrl and P: Prints a document.
Ctrl and R: Switch the alignment of a paragraph between left and right.
Ctrl and S: Saves a document.
Ctrl and U: Underlines text.
Ctrl and V: Pastes the copied item or text.
Ctrl and X: Cuts the selected item or text.
Ctrl and Y: Redo the last action.
Ctrl and Z: Undo the last action.
Ctrl and Enter: Insert a page break.
Ctrl and F2: Select Print Preview command.
Ctrl and F4: Closes the active window.
Ctrl and F6: Opens the next window if multiple are open.
MichaelTiera
keyboard shortcuts
Post by MichaelTiera »
Hi,
I like keyboard shortcuts a lot since they allow me to save so much time and nerves. Currently, I have to create lots of graphics in Inkscape with lots of alignment stuff. Alignment with the keyboard shortcuts on the keypad align top/bottom/center... works perfectly for me. There is just one problem: I really often have to change "Relative to" between "Last selected" and "Page". Therefore, I always have to open the Align and Distribute view and change it appropriately with the mouse. I did not manage to give that a keyboard shortcut. Can anybody tell me, how this can be accomplished?
