Change Page Size
CDorman
Change Page Size
Post by CDorman »
I am trying to do a print and cut with a design on Tabloid size (11"x17") paper. It looks like SCAL 4 is cutting off my design as if it were Letter size, and the printer is enlarging it to Tabloid size (see image). So I am getting a design that is twice the size it should be, and incomplete.
When hit preview, the page size is clearly letter. How can I change the page size in SCAL?
Re: Change Page Size
Will you please post screenshots of:
(1) The shape open on the Cutting Mat in SCAL
(2) File>Print Setup window
(3) File>Print Setup>Properties window
Hopefully, something will "click" when I see these three!
CDorman
Post by CDorman »
Thanks Sandy! I hadn't found the print setup window and that seems to be the culprit.
So, if you change your paper size in the bottom window... the File>Print Options from 8.5 x 11 to 11 x 17, does that fix it?
CDorman
Post by CDorman »
Yes, that fixed it. Thanks!
You're welcome!
ebonylorange
Post by ebonylorange »
Print page setup is very important .
