Colour Fill
eps26
Colour Fill
Post by eps26 »
Hi Everyone
Trying to learn scal 4.
Can anyone tell me why my colour fill doesn't show on my virtual mat. I'm using scal 4 . I select my shape - go to colour fill - select colour - choose colour then ok, I can see the colour on the layers tab but not on the shape on the mat. I have unchecked the 'show outline only' but I can only see the grid through my shape. I know it's something I'm doing or not doing so will be happy to have some help.
Thank you in advance of any reply.
Eleanor
Re: Colour Fill
Without being able to open your file to check, my best guess is that it's not a close shape. So, try selecting this shape and go to Path>Close Path to see if that resolves the issue. If it doesn't, then email your .SCUT file to me at smccauley45@cox.net.
eps26
Re: Colour Fill
Post by eps26 »
Hi Sandy
It happens to all shapes even the ones in my library, I've tried most of the shapes so it's something I've done or not done. The hearts that are red in my library are clear on my mat and I can see the grid through them though they are red in my layers . There's only one layer with the shape so that isn't the problem.Very frustrating.
Eleanor
Re: Colour Fill
Again, make sure that the Show out lines only is not checked:
Then select one of these shapes from the libary and open the Fill & Stroke Panel. With the shape selected, please verify that the Fill option shows color:
If that's not it, then please post the same screenshots I showed and also your shape selected. I've never know this to be an issue but I will try to find out more once I have verfication that you have both of those set the way I do. Very bizarre otherwise.
eps26
Re: Colour Fill
Post by eps26 »
Hi Sandy
Thank you very much for your reply. I had already done as you had suggested but noticed your workspace alpha was set differently to mine. Set mine the same and I now have colour. Once again a big thank you for all your help.
Kindest Regards
Eleanor
Re: Colour Fill
Thanks for posting back that it was the Opacity setting. I'll have to remember that in case it happens to someone else. I keep forgetting SCAL has that feature since I never use it... I never think to use it! lol
