I try to used svg file in SCAL4.050 version, i need to cut it using GCC i craft machine but it doesn't work, it only display on the gcc i craft screen the word "Printing", it does not start cutting the image. Same problem i encounter when i trace a simple image.
Photo below shows the svg file i used in SCAL4.050
I hope someone will help me on this problem. Thanks
having problem with tracing and svg file
- scal1.jpg (184.94 KiB) Viewed 10667 times
Re: having problem with tracing and svg file
It's been awhile since you posted, I hope you have figured it out but my first thought is your cutter driver installed and have you selected it in the printer list. The svg file is already traced so I believe you should be able to go to the cutter menu and select cut.
