Not exactly a cutting project, but...
Share your completed projects
Qbrix
Post by Qbrix »
I recently bought a Silver Bullet cutter, but haven't done much cutting yet. We are mostly still experimenting.
- At first we just sent the mat and paper through, but most cuts would not be precise.
- Then I tried to straighten out the mat while cutting, and this was much better!
- Today I started to make a more permanent solution, and although it is a little rough in the edges and it isn't finished yet, I like it a lot :)
The cutter is now placed ~12cm below the table, which ensures that the mat is horizontal at all times. By moving it away from the wall, I can also use my 60x90cm mat without problems.
pastda3
Re: Not exactly a cutting project, but...
Post by pastda3 »
Glad you found a solution to your problem. :)
harry56
Post by harry56 »
I have a Titan and I cut glitter vinyl at 200g force and speed anywhere from 200-450
สมัครบาคาร่า
