Image print and cut. not lining up
Brianac2002
Post by Brianac2002 »
Hi, Please help. I do a lot with sublimation and vinyl cut however I want to use the print and cut option more and I am working on a job for a charity. Hopefully you can see from my picture the cut line (pen) is not lining up. I put the laser point to the registration dot ok and pres the origin button. I know I have to tidy the line up but that is not the issue. Can anyone please assist. Sorry if I am being a bit thick.
scan print and cut.jpg (899.13 KiB) Viewed 5883 times
mitsim
Re: Image print and cut. not lining up
Post by mitsim »
Are you using ECAL or ECAL2 and the Eclips or the Eclips2? For either one, make sure you are using the most updated version. For ECAL2 with the Eclips2 there are two different calibrations to perform, so make sure both are done. The original Eclips just has the one calibration.
I use ECAL2 on my original Eclips and p2c is spot on all of the time. Good luck!
