print and cut layout problem
valveej
Post by valveej »
Hi! I'm using a GGC i-craft to make my own labels.
I save my labels in .png and for the overlay cut, I save another overlay file of the shape. Usually I make the actual label file bigger than the overlay because it tends to cut outside the shape of the actual label. No matter how I try to keep the overlay perfectly centered to cut the actual file correctly, it still cuts a little more to the other side which leaves the other one thicker. I attached the file - you can see the left side of the gray outline is thicker than the right side.
Is there anything I need to do to correct this? I also tried grouping them together but it still does this when I print + cut. I've wasted so much sticker paper and printable vinyl :( Help please!
Thanks!
