print & cut
m13shl
print & cut
Post by m13shl »
Hi I am trying to print and cut my own sentiments using scal 4 (I also have scal3).
I normally have my sentiments in circle or rectangle etc.
when I go to print it prints the shape and not the text inside.Does this make sense?
Any ideas where I am going wrong?
Thank you :D
Re: print & cut
Hi, I hope that I am interpreting your question correctly....here goes.
You need to designate both the text and the circle as P2C in the style window menu. (it is found by clicking on the wrench on the right ;hand side. The text is P2C print and the surround it P2C cut. Then you go to the cutter menu and select p-2cut. from there the software will guide you through printing, and cutting.
p2c txt.png (58.57 KiB) Viewed 1811 times
If this is not what you need try explaining it or posting your file and someone will come along and help fix it :)
m13shl
Re: print & cut
Post by m13shl »
Thanks susan I will give this a try : ) :D
m13shl
Re: print & cut
Post by m13shl »
SUSAN you are an absolute star! Totally works, Thank you, Thank you :D :D :D :D :D :D
