eCal will not start! I have the latest version. It used to run! Searching the CraftEdge forum, I found a topic for a similar problem from eCal1 back in 2013, but the suggested fix doesn't help now. Anyone else having this issue? Maybe I'll have to reinstall....
Oh, well, turns out the download link says 2.006, but when you click it, the file is actually 2.007. I ran into an error installing that update !!
eCal2 2.006 Will Not Start - 2.007 Will Not Install
- This is the error message I'm getting when I try to install the latest version.
- Capture.JPG (27.18 KiB) Viewed 3276 times
Re: eCal2 2.006 Will Not Start - 2.007 Will Not Install
Hmmmm, I tried it and only got 2.006. I wonder if CE posted 2.007 and took it down. I assume you can still open and use 2.006?
shoot support@craftedge.com an emai and see what they say!
That error is indicating the installer is trying to overwrite the old file but cannot because it is currently open.
You need to close the old version of eCAL if it is running before installing the update.
- Craft Edge
http://www.craftedge.com
