Using Inkscape for model airplane plans
pedwards2932
Post by pedwards2932 »
Having some difficulty taking measurements on airplane plans. I am tracing over pdf plans and some pieces have notches that are 1/16 inch square. I know you can measure a line as you draw it but I would like to be able to measure after it is drawn. In SketchUp you have a tape measure that you can do this type of measuring and it looked like someone was developing it for Inkscape but I don't see a measurement tool on Inkscape and I downloaded the newest version. Any ideas?
Re: Using Inkscape for model airplane plans
Hi, you might find more Inkscape guru's on the Inkscape Forum: http://www.inkscapeforum.com
I've been thinking about your question and perhaps it is a simple answer. Forgive me if you know all of this.
After drawing your line, select it and it's h and w are displayed See photo
Screen Shot 2014-08-18 at 3.30.35 PM.png (48.48 KiB) Viewed 32221 times
Also do you have grid turned on? view/grid
you can set the grid lines to different sizes in file/document properties
pedwards2932
Thanks for the help. I was able to get the grid up and get the measurements but it is still a little difficult getting the accuracy. The grid is in inch squares and the ruler is divided into 1/8" increments. I can draw a 1/16" square and use that for the notches. I need to figure out how to combine it with a curve and then delete one side of the square to make it a notch.
DogCarbon
Post by DogCarbon »
I use the 0,0 point on the virtual drawing board, to help sometimes put my object at a known location, then I can make sure the lines are straight up and down and then the horizontal also by using the nodes and their positions which you can type in the boxes.
And the Object/Align and Distribute if I want the objects aligned relative to each other (back to back or centered) before I want to combine them.
if you need more guidance, I am sure i can find some tutorials.
I should have read this post first. You can change your grid settings in the preferences too.
When you say combine the square with a curve, are you putting rounded corners on the square or removing the square from a curved shape? You can round the corners of rectangles in Inkscape, but it rounds all four corners. I don't know how to do just one or two without using two squares.
If you just want to cut the triangle (with sharp corners) from a curved shape the easiest way is to position the square where you want it, select both the square and the curved shape and use Path/Difference. Make sure that the square is above the curved shape first (z direction) since the upper shape is removed from the lower shape.
pedwards2932
Yes that is exactly what I was doing this morning and it gives a precise notch. That with the ability to get the grid in 1/16 inch is making it easier to be more precise. The notches need to be square not rounded.
newbiecat
Post by newbiecat »
Hi
You can change the end of the stroke style in the Fill and Stroke Pallete ( Shift+Ctrl+F) click on the Stroke Style tab - it is in the section called Cap
P
claricia36
Post by claricia36 »
pedwards2932 wrote:Thanks for the help. I was able to get the grid up and get the measurements but it is still a little difficult getting the accuracy. The grid is in inch squares and the ruler is divided into 1/8" increments rachat de crédit. I can draw a 1/16" square and use that for the notches. I need to figure out how to combine it with a curve and then delete one side of the square to make it a notch.
Il y a un moment, j'ai eu le même souci, mais heureusement que je suis tombé sur le forum.
Thomasd87
Post by Thomasd87 »
pedwards2932 wrote: Mon Aug 18, 2014 5:07 pm Thanks for the help. I was able to get the grid up and get the measurements but it is still a little difficult getting the accuracy. The grid is in inch squares and the ruler is divided into 1/8" increments. I can draw a 1/16" square and use that for the notches. I need to figure out how to combine it with a curve and then delete one side of the square to make it a notch.
Maybe you could send us some pictures of your project.
