Can someone make wedding pocket into an SVG please?
habarijoy
Post by habarijoy »
Hello, I'm in need of some help. I've tried to make this pocket wedding invitation myself but I totally get confused with inkscape. I'm doing this for a friend for his wedding and I have tried to do one using inkscape but my lines are always uneven. Could someone please help me and see if this pocket can be made? I would truly appreciate it.
Thank you so much.
Trakia Johnson
DogCarbon
Re: Can someone make wedding pocket into an SVG please?
Post by DogCarbon »
just looking at the inside text part, would that be 6" x 6"?
if so, the card would be in two pieces, and need to be glued together.
Is that what you are looking to do? do you need all the pieces made or just the pocket part?
habarijoy
Post by habarijoy »
Hi, I need the entire thing if possible. I've tried to attempt it in inkscape and I'm at a lost.
DogCarbon
Post by DogCarbon »
try this, let me know if you need it tweeked.
Right now it is designed so the finished-folded size is 6"x6"
wedding invite.svg
(2.87 KiB) Downloaded 661 times
habarijoy
Post by habarijoy »
Thank you so much. I haven't tried to cut it yet. About to try it now. Will let you know how it looks. Once again, thank you so much.
Thanks again
Trakia
