I am using Scal2 (so I can use it with my Cricut). I have downloaded svgs and have added them to my personal library. The svgs load into the library okay except that when I open the library to preview the svg files the ones that I have added recently only show a blank square where the preview should be. The correct name of the file displays when I hover over it and the correct file opens in SCAL. Does anyone have an idea how to fix this? It sure would save a lot of opening and closing files to find the right one. Thank you for any suggestions.
Carol
Personal Library
Personal Library
- Capture.JPG (48.5 KiB) Viewed 3392 times
Re: Personal Library
When you look at the file in SCAL, do the images have a stroke color applied?
Sandy, I'm not sure what you mean by stroke color. When I look at the file in SCAL, on the mat the has colored lines but no fill color. I have tried to fill the image using the "fill" option in the Appearance menu but it does not fill with color. I am able to see the image in Irfan SVG viewer. This problem started a while ago, so I have a number of files like this.
Carol
Carol
- Capture.JPG (29.05 KiB) Viewed 3335 times
go to the view tab and u
nclick the outlines option and then you can fill
Btna,
Thank you for your help with the fill problem. I obviously never payed any attention to that in the view menu. Now if I could only get the image to stay colored in the Personal Library.
Thanks again,
Carol
Thanks again,
Carol
you may have to resave it filled and then put it into the library
Thanks Btna, that did it!!
Carol
Carol
