In Svg or s cut.
Thanks in advance.
Ok, I’ve located a black and white image of a clock face with roman numerals. I’ve transferred it to Inkscape saved as svg file. My problem is that it’s a bit too detailed; meaning when I cut it, it a bunch of tiny pieces.. I”m thinking if the lines of the clock where a bit thicker it could work. In inkscape; is there a way to increase boldness of image? Can someone please point me in the right direction?
REVISED: Roman numeral Clock Face
- rrmclck.svg
- (49.84 KiB) Downloaded 274 times
Re: REVISED: Roman numeral Clock Face
I don't know how to do it in Inkscape.... but here is a bolder copy.
Robyn
Robyn
- roman Clock.svg
- (76.09 KiB) Downloaded 344 times
If you want to make thicker lines in inkscape, select what you want thicker (or larger) and in the menu use Path/outset. Do this as many times as you need to get the lines as thick as you want.
