Soccer ball?
piazza
Soccer ball?
Post by piazza »
Hi Everyone,
does anyone have a good soccer ball with the black lines thick enough that it doesn't jam up while cutting? All the ones I can find out there have really thin black lines. :D
Thanks so much, Mary
Robbyynn
Re: Soccer ball?
Post by Robbyynn »
Try this one.
soccer ball Robyn.jpg (53.55 KiB) Viewed 39671 times
soccer ball Robyn.svg
(2.72 KiB) Downloaded 5470 times
piazza
Re: Soccer ball?
Post by piazza »
Thanks so much, that is EXACTLY was I was looking for. Now I've got a ball for my little guy's soccer layout :D
Robbyynn
Re: Soccer ball?
Post by Robbyynn »
You're Welcome!
Robyn
nurse2003
Re: Soccer ball?
Post by nurse2003 »
i'm having a problem cutting this file for the "black" part it cuts the outside circle first and then when it goes to cut out the little pieces inside my little circle unattaches from my paper, is there anyway I can tell it to cut the little pieces first then around the outside?
Re: Soccer ball?
Go to Edit and Select All
Object and Break Apart
Windows for the Layers Panel, and turn off with the eye that which you don't want to cut right away, then after it cuts turn of the layers that cut, and turn the eye back on for the final ones you want to cut last.
Actually, when you turn off the outside part and have the insides showing, you can select all of them and GROUP, and then they all turn on and off at the same time for that section, etc.
