I am trying to move some shapes off the mat completely so I can work with the other shapes.
But I get to the edge of the mat and they won't go any further. Can someone tell me why or is there a setting I need to
change.
Thanks so much
Tam
shapes won't move off the mat
Re: shapes won't move off the mat
Go to Edit at the top and then Preferences and then Edit again and uncheck the top box. Actually, I unchecked the top 3 boxes to make things work as I like.
O thank you so much. I knew I was doing something wrong because I know when I first used Scal I could move them off the mat. Thanks for the heads up.
Tam
might be worth taking note or screen shots of those settings windows.
sometimes, when you upgrade or reinstall scal (or even the OS) settings can be reset to defaults etc.
at least then, you have a good chance of finding a errant setting
Gaz
Gaz
Computer:IMac running Mojave
