I am unable to use the select all. Is there some kind of trick to using it that I cannot figure out? Also, I read in another thread about grouping and ungrouping; can someone explain to me how to do that? I am fairly new to the program and I am still learning. Thanks for your help.
Julie
P.S. It's nice to be here. I love the forum!
Grouping and Select All
Re: Grouping and Select All
Here is how I would explain it.. You need to type or select all your letters or the designs you want. They will all be in one box.. If you want them welded .. select the weld button while the box is highlighted. The you can click on each individual item to highlight it and you can move at manipulate them item.
There is a video someone has made showing this on Youtube... http://www.youtube.com/watch?v=CBUACnv3 ... re=channel and http://www.youtube.com/watch?v=YXPC6mkY ... re=channel
Hope this helps..
Hope this helps..
