Row of candles
lindamac
Row of candles
Post by lindamac »
Here is the SVG file for the candles I posted in the tut for embossing folders. Enjoy!
candles.svg
(12.87 KiB) Downloaded 489 times
kelsie94
Re: Row of candles
Post by kelsie94 »
This is great Lindamac. Thanks. Can you advise if the 60 degree blade is the same as the deep cut blade? I've never heard of the 60 degree one!
lindamac
Re: Row of candles
Post by lindamac »
From what I have read on the Cricut forum, It sounds like the deep cut housing uses a 60degree blade. You can find them on e-bay pretty cheap. Just type 60 degree roland blade in the search engine and some should pop up. I used the blade in my regular housing and it worked just fine.
kelsie94
Re: Row of candles
Post by kelsie94 »
lindamac wrote:From what I have read on the Cricut forum, It sounds like the deep cut housing uses a 60degree blade. You can find them on e-bay pretty cheap. Just type 60 degree roland blade in the search engine and some should pop up. I used the blade in my regular housing and it worked just fine.
That's great if you can use them in your regular housing cause I'm pretty sure the housing for the deep cut is quite expensive. Thanks again!
wreed06
Re: Row of candles
Post by wreed06 »
So are you saying the deep blade and the 60 degrees blade are the same thing, just called two different things?
