What size fonts would you do
hairco
Post by hairco »
I would like to make one of these but don't know size lettering i can do it in to keep it from tareing when i weed it
dragonlord666
Re: What size fonts would you do
Post by dragonlord666 »
it would depend on the size of the balloon. inflate one and measure the diameter (across from side to side)
draw a circle that size
type your text and then resize that to fit inside the circle
that is the biggest you can have your text - do a test cut to see if it work on some scrap vinyl.
if you don't mind the text wrapping around the balloon a bit you can go a little bigger
or forget the balloon and use a paper circle to put the text on..... would make it one dimensional but that would mean it would hang on a wall better.
and you can use any sized circle & bigger text :)
Gaz
Computer:IMac running Mojave
DogCarbon
Post by DogCarbon »
I have seen this ornament posted before... and if I remember the size of the ball is 4" diameter... so it is fairly large. Bigger is gonna be better in this case.
I would even consider warming the vinyl with a hair dryer before weeding.... and while placing the text on the ornament.
dragonlord666
if you use transfer tape, make sure it's not too sticky, or you could burst the balloon pulling it off :)
oh an no poky tools for placing the letters, sharp and balloons is not a good combination LOL
Gaz
How about if you use PLACE in scal with this picture and then Keep Proportion box checked...then make the ornament circle size of 4 inches with a round circle from the Shape Library, and stretch the picture larger till the ornament fits the circle...then you have sort of a guide for the font sizes, maybe.
