Cutting wedding program fan
rainbow82
Post by rainbow82 »
Hi All
I found a SVG on the internet, I took the text off and I tried to trace it, but it will not trace no matter what I do. I tried played with it for over 1 hour. I tried doing it in Inkcape then when that did not work directly in SCAL. I am not sure what I am doing wrong. I watched youtube videos, I read help guides, I am at a loss.
I have not used my SCAL in a long time, so I am not sure if I need to upgrade something. Last time I used it it worked fine. Can someone please help me or give me another direction to go in. Other then that I am going be cutting out 450 fan pieces by hand!
np group.svg
This is the one I removed the grouping from
(24.42 KiB) Downloaded 304 times
fan no text.svg
this is the one with no text
(25.06 KiB) Downloaded 341 times
Re: Cutting wedding program fan
I think this is what you intended. A google search came up with what looked like your template.
http://www.athomealterations.com/2010/0 ... grams.html
The template is designed to 4 blades at one time and then you assemble them together. If this is the right one, e can work from there.
See if this is what your want. You can cut 4 per 12x12 sheet of cardstock.
I don't know how you want to add the text. You say that you haven't used SCAL for awhile so I'm guessing that you have SCAL2 so do you know how to add text for print to cut?
weddinfanPS.svg
(15.06 KiB) Downloaded 317 times
weddingfanPS.scut2
(62.66 KiB) Downloaded 221 times
OH...now I see what this is all about...thanks PS!...mine was all wrong, and so I removed it.
dragonlord666
Post by dragonlord666 »
why were you tracing an SVG?
just import it into scal or use a inkscape plugin to send it to scal?
Gaz
Computer:IMac running Mojave
rainbow82
Post by rainbow82 »
Thank you this is the correct file I am going to see if I can cut it now!
i did try to do it without tracing but it would not cut anything
dragonlord666 wrote:why were you tracing an SVG?
Gaz
Gaz, You are correct in that you don't trace an svg but this file was not properly constructed for svg cutting. If you imported the svg file into SCAL2 or eCal you would see that there are a ton of line segments not connected. SCAL2 doesn't like them and eCal only does a fair job wth them. It would not union in SCAL2 and did a poor job in eCAL. It would not union in Inkscape either. the only answer was to reconstruct a whole element.
fan SCAL2.png (78.77 KiB) Viewed 5648 times
In ecal it would do a Union but this is the result.
fan ecal AM.png (26.61 KiB) Viewed 5648 times
I hope this helps some, new or old to figure out why not all svgs work in SCAL
dragonlord666
Ah, I always (well 99.999%) open in inkscape, I tend to use Scal3 as I would a printer driver, except for a small, last minute edit if I forget something (like forgetting to add/remove a dash line)
if I can't union all the bits as in this file I would just fill the shape with colour (bucket fill) and then use that as the svg, deleting the outside (stroke)
the shape may be a little smaller but svg can be resized so not a bit problem and it's only by a small amount that you'd not really notice.
Gaz
dragonlord666
using the OP files I get this after using the paint bucket/bucket fill (stroke no fill)
Blue is the first file, red the 2nd.
I then don't have to worry about union at all as each blade is a individual object, I could group them if I wanted.
Fans after bucket fill.png (167.39 KiB) Viewed 5597 times
Last edited by dragonlord666 on Mon Nov 19, 2012 10:27 am, edited 2 times in total.
Thanks Gaz, I did use the paint bucket to get the elements together.
For those of you who don't know how to use the paint bucket see Cleversomeday's video's and tutorials for everything you need to know about using the paint bucket.
http://cleversomeday.wordpress.com/?s=P ... tton=Go%21
