halloween candy corn treat bag
angel
Post by angel »
Its up to you to decorate, or image fill with a halloween paper pattern and do print to cut. This is big enough to put little candies in. The base finished size is 3" x 3" and its 2 1/2 inches deep. All you need to put this together is 4 small pieces of double sided tape.
candy corn side.JPG (107.75 KiB) Viewed 11574 times
candy corn front.JPG (100.14 KiB) Viewed 11574 times
angel
Re: halloween candy corn treat bag
Post by angel »
Its telling me file is to large, give me a sec.
candy corn treat box.svg
(4.66 KiB) Downloaded 370 times
angel
Post by angel »
Gj1 can you tell me why the scut file wouldnt load, it said is was to big, so I exported it as svg and it seems to have uploaded that way fine.
This is a GREAT container!!! TFS, and regarding the size of the file...I am not sure...I have not had a problem with that in a long long time...have uploaded files with many pages, so I can not say why...but export to .svg is the answer if it will lot load.
pastda3
Post by pastda3 »
Angel - this is a really cute treat box. :) Thanks so much for the file. I cut it out and made the white and yellow parts for the candy corn. Unfortunately, the score lines were solid and cut it into separate pieces. I'll have to be more careful next time. :oops:
angel
Post by angel »
awww, im so sorry!! I forget that not everyone has an eclips machine, but you can easily change in scal, I always do the solid with the eclips its much faster than the dashed cuts, I will post next time that it has solid score lines, very sorry.
