Here is another one for you, again cut from 1mm matboard as sold by Dawn.
This one is a real brain teaser to assemble, fortunately the original file had most of the slots numbered so I have attached that for you too.
I think maybe some of the slots could do with being a bit longer to make it a bit more stable, I might re-work it eventually.
Here it is..
3D Ceratopsier Model
- Ceratopsier-1mm Mountboard-1.jpg (109.29 KiB) Viewed 8841 times
- Ceratopsier model help.svg
- (530.96 KiB) Downloaded 519 times
- Ceratopsier model.svg
- (111.12 KiB) Downloaded 508 times
Re: 3D Ceratopsier Model
This is awesome, but there is no way I would want to tackle that. I don't have the patience.
Took about 5 or 10 mins tops to cut, and I would say roughly 15 minutes to assemble.pastda3 wrote:This is awesome, but there is no way I would want to tackle that. I don't have the patience.
