I have been slowly trying to catch up on cards for OWH. we have so many birthdays, anniversaries, etc in May that I am behind. I tried a new technique on the butterfly and dragonfly and I found the birds online and just like them.
Jan
New cards and techniques
- IMG_0118 [iPhone].JPG (24.42 KiB) Viewed 2002 times
- IMG_0117 [iPhone].JPG (22.17 KiB) Viewed 2002 times
- IMG_0116 [iPhone].JPG (31.18 KiB) Viewed 2002 times
Re: New cards and techniques
ALL BEAUTIFULLLL!!! Are those all embossing that you have inked...butterfly and dragonfly and behind the dragonfly? OH boy...you did a nice job!!!
The technique is really simple. Cover a die cut with metal tape (check hardware stores) then emboss it by running it through your machine. After that you can ink or use paints, let them get almost dry and then wipe some of it off! Simple and really cool.
Jan
Jan
Oh, it did not look like the foil...I have done this before...just cut the shapes with the cutter and embossed, because I don't have any die cuts. But it works. Thanks!
