Simple square window card
Posted: Tue May 15, 2012 2:34 pm
by lk2thestarz
I need a square svg file that has 3 sides that are cut, and one side a perforated line. A swinging window. Thank you so much!
Re: Simple square window card
Posted: Tue May 15, 2012 4:26 pm
by sstehman
Here is a square with one side as a perforated line.
Posted: Tue May 15, 2012 6:49 pm
by lk2thestarz
Oh thank you SO much!!
Posted: Tue May 15, 2012 6:50 pm
by lk2thestarz
Would it be possible to convert the file to an svg and not an scut file?
Posted: Tue May 15, 2012 7:24 pm
by pastda3
When you open a file in SCAL3 (or 2), you can export the file and save it as an svg.
Posted: Wed May 16, 2012 3:37 am
by sstehman
Here is an svg and an scut2. You can change an scut3 file to an scut2 file just by changing it in the name of the file. Not sure if you are using SCAL or eCAL, but it will work with both by just changing the file designation.
As in previous post, you can export as an svg from either software version but on export as svg and on opening in INK I needed to change the perforated line style, so it is now done for you.
