Simple square window card
lk2thestarz
Post by lk2thestarz »
I need a square svg file that has 3 sides that are cut, and one side a perforated line. A swinging window. Thank you so much!
sstehman
Re: Simple square window card
Post by sstehman »
Here is a square with one side as a perforated line.
Square with Perforated Line one Side.scut3
(28.27 KiB) Downloaded 173 times
lk2thestarz
Oh thank you SO much!!
lk2thestarz
Would it be possible to convert the file to an svg and not an scut file?
pastda3
Post by pastda3 »
When you open a file in SCAL3 (or 2), you can export the file and save it as an svg.
sstehman
Post by sstehman »
Here is an svg and an scut2. You can change an scut3 file to an scut2 file just by changing it in the name of the file. Not sure if you are using SCAL or eCAL, but it will work with both by just changing the file designation.
As in previous post, you can export as an svg from either software version but on export as svg and on opening in INK I needed to change the perforated line style, so it is now done for you.
Square with perforated side.svg
(2.34 KiB) Downloaded 162 times
Square with Perforated Line one Side.scut2
(28.27 KiB) Downloaded 138 times
