Paper Plate Angels
Craigg64
Paper Plate Angels
Post by Craigg64 »
Hi
Saw these on this site http://www.marthastewart.com/good-thing ... ate-angels
Thought I would give it a go on the cricut
Here is my file.
Hope you like them
Sorry People I only put one angel up. Here is both of them. The file is setup to cut 2 of both angels out of a 12 x 12 card.
These are going to be our placecards for Xmas lunch
Also thanks AnointedHands :D
Cheers
Craig
Both Angels.JPG (19.14 KiB) Viewed 4685 times
angels.svg
(10.47 KiB) Downloaded 348 times
angel.svg
(3.88 KiB) Downloaded 407 times
Cheers
Craig
lovebeingamom
Re: Paper Plate Angels
Post by lovebeingamom »
that is great, thanks
kelsie94
Post by kelsie94 »
Very cute! thanks.
lowcarbgirl
Post by lowcarbgirl »
OM Gosh - that is wonderful! Thank you!
lowcarbgirl
Craig,
Can you help me - I love the angel but I want to do the one with the Angel's hands down.
Can you tell me, please, how to turn the PDF file into an cuttable file - I have inkscape and the SCAL.
Or you can can convert the other one for me if you don't want to share the directions on how to convert? (But I would really like to have the directions so I can do other PDF projects.
Craigg64
Post by Craigg64 »
lowcarbgirl wrote:Craig,
HI
I have no problems sharing but I Cheated :)
I Used Coreldraw and imported the the pdf into it. Coreldraw can read PDF files and if the pdf was created from a drawing package it can break the pdf apart into the original line work.
Then saved it as a SVG and did the rest in inkscape.
I could have done all of it Coreldraw but I want to get experience in using Inkscape.
The funny thing though was it all sounds easy but when I tried to import the original Coreldraw svg file to SCAL, SCAL was going to make some strange cuts. So I ended up spending some time in Inkscape cleaning the SVG up by making all cut lines all part of one object (1 closed object).
My file on the forum has both angels in there so you should be able to open the SVG in Inkscape and delete the ones you don't want.
If you have any trouble I can separate the angels for you
Cheers
Craig
Cheers
Craig
lowcarbgirl
Craig - I saved you SVG file and when I open it there is only the angel with hands above her head... I can't see or find the other one.
Please do help me.
Craigg64
Post by Craigg64 »
lowcarbgirl wrote:Craig - I saved you SVG file and when I open it there is only the angel with hands above her head... I can't see or find the other one.
Please do help me.
Silly me. ;)
I have only uploaded the single angel.
I will upload the other angel tonight.
Cheers
Craig
Cheers
Craig
AnointedHands
Post by AnointedHands »
I have both angels. I have posted it below.
angel II.svg
(5.59 KiB) Downloaded 240 times
lowcarbgirl
Craig -
A MILLION THANK YOUS!!!!
I am going to be busy later today.
Brenda
