Man With Flower - card P2C
This is so totally not my style since I'm not much for doing final projects let alone with all this color and pattern but I was playing with my little guy and decided I could use patterns to fill him in, just to see what I could learn by doing it. I did it in Inkscape but SCAL and eCAL both have the capabilties of using patterns. I like the ones from patterncooler.com but any seamless pattern works.
You can get the digistamp from my Blog if you want to give him a go. The scalloped frame is from my Hibiscus card if you want that too.
Screen shot 2012-02-09 at 1.37.35 PM.png (178.32 KiB) Viewed 3652 times
Re: Man With Flower - card P2C
Patterns look good and I like the white bg very much!
mommabird52
Post by mommabird52 »
This is soooopoo cool! You are very talented!
judyjo
Location: Indiana, Mac v.10.5.8, Inkscapes, Scal v. 2.013, Cricut Expression, Design Studio, eclips, eCAL
Post by judyjo »
Very cute card Susan. Your sense of "play" is really cool :!: Thanks for sharing and also thank you for mentioning patterncooler.com......I had never heard of it before. So, I checked it out and they do have some really interesting patterns. Now........I have a question. After downloading a pattern, I was able to open it in SCAL, but couldn't figure out how to save it to the pattern library. Is this possible?
Judy, although you could add your new found patterns to the Pattern Library I would not suggest doing so as they increase the size of the program and can slow it down.
Instead I put all my seamless pattern pieces in one folder (however you like to be organized.) and then I select the one I want as needed for a particular element.
See if this helps on how to do it in SCAL. It is not any different in eCAL, just the screen looks different. Let me know if this works for you. I did it very quickly.
Apply Pattern Tut.png (229.2 KiB) Viewed 3585 times
judyjo
Post by judyjo »
Works perfectly for me, thanks for your help. Also, I really appreciate your hint about the pattern library size.
ptpulley
Post by ptpulley »
Thank you for the instructions!!
I use a BabyBug, SCAL2.
