How to make a word book?
shazzy103
Post by shazzy103 »
I have spend 3 hours trying to make a word book using both inkscape and scal... I read susanbluerobot tutorial.. when I make the rectangle then try add letter to it i have put it in the same size as the box but it ends up being smaller and when i try and stretch the letter to be inline with the box i cant get a perfect fit. I am tearing my hair out here if anyone can help I will be eternally grateful
myscrapchick
Re: How to make a word book?
Post by myscrapchick »
Can you tell me what word you are trying to do?? Maybe I can help. Please email me at the below email addy. I am not always here to answer you. :)
myscrapchick@comcast.net
hugs, Kristi
www.myscrapchick.com
shazzy103
Post by shazzy103 »
Thank you so much Kristi for your kind offer, but finally worked out how to do it on inkscape using a tutorial from another forum :D
Stazzi
Post by Stazzi »
I know it has been awhile, but can you please post the link to the tutorial that you found? I am not even sure if what you were trying to do is what I am looking for... I would appreciate it regardless.
Thanks!
Nelliesil
Post by Nelliesil »
Can you please post the link to the tutorial that you found? to make the workbook with inskcape
thanks,
Nellie
raewyn64
Post by raewyn64 »
To make a basic word book you don't need to use Inkscape.
Just use SCAL - use the rectangle shape and pick your font and weld the letter and the rectangle together and then cut. Just make each recatangle longer (or start with the last letter and make it the length you want your book to be and then shorten it for each letter that comes before it).
Hope that sort of makes sense.
Also Susan Bluerobot has a lesson on her web site showing how to make a word book with Cricut - which is the same principle as using SCAL
http://susanbluerobot.blogspot.com/2008 ... -book.html
or check out the word books posted under svg on this message board which might give you some help
http://forums.surecutsalot.com/viewforum.php?f=39
Raewyn
Nelliesil
Post by Nelliesil »
Thank you very much for the Info.
Nellie
shazzy103
Post by shazzy103 »
